libs..aar file into the libs directory.Initialize the SDK in your Application class or the onCreate method of your main Activity:
import android.app.Application
import android.view.MotionEvent
import com.cleartrust.cleartrustadfraudtestingapp.android.ct_fraud_detection_sdk.*
import kotlinx.coroutines.CoroutineScope
import kotlinx.coroutines.Dispatchers
import kotlinx.coroutines.launch
class MyApplication : Application() {
private lateinit var CTSessionManager: CTSessionManager
private lateinit var CTDeviceMovementMonitor: CTDeviceMovementMonitor
private lateinit var CTTouchTracker: CTTouchTracker
private lateinit var CTApiClient: CTApiClient
private lateinit var CTDeviceInfoManager: CTDeviceInfoManager
private lateinit var fraudScore: CTFraudScore
private lateinit var CTAppUtils: CTAppUtils
override fun onCreate() {
super.onCreate()
CTApiClient = CTApiClient(this)
CTAppUtils = CTAppUtils(this)
CTDeviceInfoManager = CTDeviceInfoManager(this)
CTSessionManager = CTSessionManager(CTApiClient)
CTDeviceMovementMonitor = CTDeviceMovementMonitor(application, CTAppUtils, this)
CTTouchTracker = CTTouchTracker()
val uuid = CTAppUtils.ctGetDeviceInfo().uuid
val apiKey = "YOUR_AUTHORIZATION_KEY"
fraudScore = CTFraudScore(this, uuid, apiKey, s1="", s2="", s3="", s4="", s5="", s6="")
fraudScore.startFraudScoreUpdates()
CTAppUtils.ctRequestPermissions(this)
val coroutineScope = CoroutineScope(Dispatchers.Main)
coroutineScope.launch {
fraudScore.ctGetFraudScore()
CTDeviceMovementMonitor.startMonitoring()
override fun onDestroy() {
super.onDestroy()
CTDeviceMovementMonitor.stopMonitoring()
fraudScore.stopFraudScoreUpdates()
override fun dispatchTouchEvent(event: MotionEvent): Boolean {
CTTouchTracker.trackTouches(event, this)
return super.dispatchTouchEvent(event)
YOUR_AUTHORIZATION_KEY with your actual authorization key:val apiKey = "YOUR_AUTHORIZATION_KEY" AndroidManifest.xml file:<uses-permission android:name="android.permission.INTERNET" />
<uses-permission android:name="android.permission.ACCESS_NETWORK_STATE" />
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_WIFI_STATE" />
<uses-permission android:name="android.permission.BLUETOOTH" /> Update your build.gradle.kts file with the following dependencies:
dependencies {
// Your existing dependencies
implementation(fileTree(mapOf("dir" to "libs", "include" to listOf("*.aar"))))
implementation("com.squareup.okhttp3:logging-interceptor:4.10.0")
implementation("androidx.lifecycle:lifecycle-process:2.6.2")
implementation("com.squareup.retrofit2:retrofit:2.9.0")
implementation("com.squareup.retrofit2:converter-gson:2.9.0")
implementation("com.squareup.okhttp3:logging-interceptor:4.11.0")
implementation("org.jetbrains.kotlinx:kotlinx-coroutines-android:1.7.3")
implementation("com.squareup.okhttp3:okhttp:4.9.3")
implementation("com.google.code.gson:gson:2.8.8")
The fraud score is calculated based on various factors. To retrieve the score from the SDK, use the following function:
val score = fraudScore.ctGetFraudScore()If the function returns null, default the value to 0.
s1 to s6) during the initialization of CTFraudScore:fraudScore = CTFraudScore(this, uuid, apiKey, s1="value1", s2="value2", s3="value3", s4="value4", s5="value5", s6="value6")
8.Bundle ID and App Name
Pass your application's Bundle ID and App Name to the SDK by setting the s5 and s6 parameters
during the initialization of CTFraudScore.fraudScore = CTFraudScore(
context = this,
uuid = uuid,
apiKey = apiKey,
s1 = "",
s2 = "",
s3 = "",
s4 = "",
s5 = "your.bundle.id", // Replace with your actual Bundle ID
s6 = "YourAppName" // Replace with your actual App Name
Ensure you replace "your.bundle.id" and "YourAppName" with your application's actual Bundle ID and App NameThis completes the integration of the ClearTrust Fraud Detection SDK into your Android project.
